oil gauge 80 psi
Old Dec 3, 2010 | 01:00 PM
06SilverBirch's Avatar
formerly 98wytebord (3-14-2012)
Default oil gauge 80 psi
When I got into my 06 sierra cc today I noticed that the oil psi is pegged out on 80. I checked the oil level and it was good. Does this sound like the stepper motor going out or went out? If this sounds like my problem does anyone have a part # or how hard is this to fix. When I turn the key forward it goes to 80. When I start the truck it goes to 0 then back to 80 and stays. Also a 5.3L. Any help on this please thanks. Brandon
Old Dec 3, 2010 | 02:46 PM
stranger ranger's Avatar
thats strange, mine only goes to 80psi when i'm around 6500 rpm lol
Check ebay motors for that cluster. I believe there was a guy in florida rebuilding them on the cheap.
Old Dec 3, 2010 | 04:08 PM
Stranger ranger thanks for the input but it stays at 80 psi no matter what rpm. I think its in the cluster like you said.
Old Dec 4, 2010 | 09:40 AM
tsduke03's Avatar
Could be oil sending unit.
Old Dec 4, 2010 | 10:26 AM
budhayes3's Avatar
PT's Slowest Truck
The 03-04's were notorious for cluster problems, and I hear of cluster gauge failures in other years sporadically. Actually don't hear of too many sending units failing, but it does happen obviously...a lot of sending units get replaced from guys snapping them while removing the intake or engine lol.
Old Dec 4, 2010 | 10:48 AM
whitedakota's Avatar
my 05 cc is actually pegged at 80 also. the same exact way you described. im leaning towards the sending unit as being my culprit also. i just replaced my knock sensors about a month prior to my gauage being pegged. ive reaced back there and its plugged in good, so i guess im gonna replace it one of these days. mines been pegged about 3 months now...
Old Dec 4, 2010 | 12:02 PM
Yes mine just started doing it and it just bothers seeing that gauge like that even though I know its not that high,well I would hope not. Where is this sending unit located?
Old Dec 4, 2010 | 03:33 PM
tsduke03's Avatar
Top back of the block behind the intake.
Old Dec 5, 2010 | 09:50 AM
You could try installing a "real" oil pressure gauge instead of relying on the so called dummy gauge, if you really wanna know what your oil pressure is.
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
