Oil Filter brands (again)
Old Jul 17, 2007 | 08:15 PM
GTOsRamairSilverado's Avatar
Originally Posted by Holty
Kevin, is that the short standard filter or the longer "extra capacity" filter? thanks.
what is the difference between the short and the long filter if any beside the size?
Old Jul 17, 2007 | 08:39 PM
budhayes3's Avatar
PT's Slowest Truck
I think that the only difference is that the longer filter holds more oil and has more filter media.
Old Jul 17, 2007 | 09:11 PM
truckmann's Avatar
Wix filters for me.
Old Jul 18, 2007 | 05:43 AM
beastmode's Avatar
Import Moderator
bingo... thats the 2006, the 1007 i THINK is about an 1-1/2" shorter
Old Jul 18, 2007 | 09:30 AM
negativeswitches's Avatar
i'm still using the napa gold filters
mostly cause i work there tho :-p
Old Jul 18, 2007 | 12:27 PM
krambo's Avatar
You are correct. The extra filter media and capacity are the real reasons I use this filter. ...although the 1" nut is nice
I believe if you look up a 99NBS 5.3L the chart states the HP2006 however any later than that, it references the smaller filter. I never really understood this except for the possibility of oil drain-back,...but doesn't the K&N's have the anit drain-back technology?
Old Jul 18, 2007 | 12:55 PM
truckmann's Avatar
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
There is an interesting read on some oil filters.
Old Jul 18, 2007 | 01:32 PM
Mark Johnson's Avatar
Great article- thank you very much.........
Old Jul 19, 2007 | 09:41 AM
shandy294's Avatar
I've used only Wix for many years since i saw one of those comparison displays (vs Fram and one other brand) in a store.
Old Jul 19, 2007 | 07:14 PM
o2man98's Avatar
Don't want to beat a dead horse, but I figured I'd start a new thread on an old subject to see what the flavor of the week is for oil filters. I ran out of my AC Delco PF-59's and have to choose which filter to run next time around. I've considered the AC Delco UPF filters (not sure if it's 44 or 46), but also read of guys liking the K&N 2006 or the Mobil1 206 filter, as well as the Napa Gold which is a Wix filter. I really like the looks of the Amsoil filter, but it's pretty expensive, although I could buy a bunch of them online. I plan to start using Amsoil in the engine FWIW.
(Both the K&N and Mobil1 filters are readily available at the AutoZone a few miles from my apartment).
So whatcha's like and why?
It may seem biased but I would have to choose the AMSOIL filters over the more common ones available. I have a few old (circa 2002) PF59's in the garage and I will continue to use the AMSOIL filters over them.
You will need the EaO64 as the longer version of the truck filter. This is the filter that I run on my Silverado and ran on the Trailblazer when we had it.
Keep in mind the you can purchase in cases of 12 (part # EaO64CS) to save about $1 a filter. Check them out: http://www.amsoil.com/StoreFront/eao.aspx?zo=1436102
