Oil cap breather
Old Feb 4, 2012 | 01:32 PM
RST302's Avatar
Default Oil cap breather
Recently installed a oil cap breather and my check engine light came on. Any ideas? It's an 06 silverado 4.8. Codes are P0171 & P0174
Thanks in advance
Old Feb 5, 2012 | 03:21 PM
Slammed96's Avatar
Pull the breather off and it will solve your problem. What is happening is it is allowing unmetered air to be pulled in through your PCV system, which is why it is setting codes. The only time you will want to run a breather on your truck is if you block off the PCV and run a catch can setup.
Old Feb 5, 2012 | 09:17 PM
RST302's Avatar
Thanks,
Old Feb 6, 2012 | 11:01 PM
06SilverBirch's Avatar
formerly 98wytebord (3-14-2012)
Yep just seen this in another thread. Check out the pcv/catch can thread lots of good info.
Pimpinpete
43
Dec 22, 2017 08:13 AM
OHsixLS3
Nov 22, 2015 07:45 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
lxcoupe
Sep 25, 2015 12:36 PM
