OEM Fog lights
Old May 5, 2018 | 07:49 PM
someotherguy's Avatar
You may still need the BCM programmed to activate the option.
Ugh...what a gyp. Sorry if I gave bad info on that. Surprised the earlier years of the same generation are different, but I suppose I shouldn't be.
Originally Posted by Madgrty
Good to know on hitting the dome over-ride 3 times in a row! Thanks! And I’ll be giving it a shot here soon. Currently trying to convince myself the shipping price from GMPartsDirect is worth it since I’m ordering a whole bumper
Before you pull the trigger, run the same part #'s through a search and try several different dealers. GMPartsdirect usually has decent prices listed but then nail you on the S&H. Put everything in the cart and get the quote based on your zip; I bet you can find the exact same parts considerably cheaper with a little work.
Richard
Old May 5, 2018 | 09:40 PM
Madgrty's Avatar
Thanks! I’ll search around and see what I can find
Old May 6, 2018 | 12:24 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I do NOT recommend GM Parts Direct.com There customer service blows...
If you look around you will find more bad reviews on them and it will make you think twice.
I use https://www.wholesalegmpartsonline.com/ for parts look up only. Most stuff I can get through my local dealer with about a 20% off list price. Sometimes I can find some of the smaller stuff on Ebay for a reasonable price and save all the hassle.
Old May 6, 2018 | 12:45 AM
1FastBrick's Avatar
All good. I had a 2000 for several years as my first full size truck.
Somewhere I have that stupid OEM fog light kit. Never did install it. have no clue where it would be....
I also have the 7 pin upgrade Towing Harness somewhere too...
Mine only came with a 4 pin connector.
I think the actual Towing package came with a 7 pin connector on the hitch and a trans cooler. Like the later trucks. Mine had a different hitch and did not have an external trans cooler. I bought the factory trans cooler Kit to install it. Came with 2 new lines and an external trans cooler.
If you look at the 99 extend cabs they only had 3 doors. The driver rear did not open it was a solid quarter panel. Some early 2000's came that way too.
Lots of weird little things with these trucks
Old May 8, 2018 | 09:09 AM
powertouring's Avatar
99-02 Press the dome override button in and out 3 times and the lights shut off.
I dont think that works on the 1999.
Does anyone know if changing the switch or body control module would update that to making the 1999 work?
Old May 8, 2018 | 11:16 AM
trxmxzx's Avatar
13 Second Truck Club
i was told no when I looked into it many years ago for mine-
even if you switch clusters with a 2000-2002 year your 99 has different wiring/programming and your airbag light will stay on
Old May 8, 2018 | 09:02 PM
adriver's Avatar
If that was me, Id spend the time to go to a yard to find a bumper. Not sure if you want your truck and 11 out of 10, but it is damn near 20 years old. I like rockauto.com for parts. They seem to be the best price on most things when I search. When you order something they will also send you a code for 10-20% off your next order. The code is usually good for a couple months, and it always says to share the code with a friend. Not sure if someone has a current code, I couldn't find one in my email. Might be worth buying something cheap just to get a code and then make your big order. Not sure if its stupid to say, but ebay and amazon is worth taking a look (to me). I'm learning how many ebay sellers sell the same stuff through ebay as amazon, but somehow use the amazon prime shipping to ship for free, even though its listed on ebay.
As for the fog lights, there are plenty of threads on this, (might not be on this forum o.0 ). Still not sure whats allowed, so I'm not linking other websites in case. If you want to do this all oem, you need a wiring harness, valence, fog lights, brackets, and even though it only takes a couple minutes tops, whats probably the most expensive part is the programming.............. You can just run a wire to each plug, ground each light, and wire it up to an aftermarket switch in the cab and to power. It wouldn't have that OEM button, and not sure if anything shows up on your dash, but its probably the difference of a couple hundred bucks total to maybe $50, and the only visible difference would be the button/ on-off switch you choose.
Old Jul 5, 2018 | 04:39 PM
silentbravo's Avatar
5 Year Member
I've never seen a 10%+ discount for rockauto.com, but I have got a few 5% discounts from them through email. I would have loved to find a larger discount from them, rockauto is usually a really good place to look for parts and are actually competitive to amazon in some cases.
There is another way to kill the automatic headlight feature. It involves splicing in a resistor to some BCM wires, and that allows you to turn on/off your lights with the ****. If you search google: "silverado automatic headlight disable" you will find lots of info, or you can PM me I did the mod myself and posted it to another forum I can link you to it. I'm not sure how picky the forum rules are here, sending people off forum for info...
Old Jul 5, 2018 | 10:48 PM
_zebra's Avatar
makes children cry
The 03- up is wired different, different plug I believe.
that don't work on 99s
i just unplugged the dashboard photo sensor & taped a resistor in the plug. been working perfectly for 10yrs now. can't remember the resistor value - you'd have to dig around here to find it.
Old Sep 6, 2018 | 10:38 AM
S14serge's Avatar
Yeah best way to do this would be to wire them yourself from the fuse box. This won't be hard at all to cleanly install taking your time.
blackpala96
May 5, 2014 02:04 PM
chris092183
Feb 20, 2011 11:45 AM
bbreed
Sep 15, 2010 04:09 PM
jk ws6 ta
Jul 24, 2008 09:25 AM
Scream
Jun 8, 2007 04:22 AM
