not getting any tailights on trailer
Old Mar 25, 2007 | 07:43 PM
ty02silv's Avatar
Default not getting any tailights on trailer
this is probably in wrong forum but i bought a 02 silv and when i checked the blinkers on the plug in for the trailer they work but the runing lights dont? do i have to buy a wiring harness to make the seven pin connector work?
Old Mar 25, 2007 | 10:14 PM
Tootall's Avatar
you can use a flat 4 connector . . . what's on your trailer side, is it a flat 4 also?
Old Mar 25, 2007 | 10:42 PM
kbracing96's Avatar
Check the fuses under the hood, Probable just a blown fuse.
Old Mar 26, 2007 | 06:48 PM
97sicksled's Avatar
x2 Also if it is a fuce you want to check the connectors running the whole way from the taillights to the fuse block to make sure you didn't burn up a connector. My brake lights kept popping fuses and it ended up burning a connector and i had to wire it together when the connector wouldn't keep the current going.
nabozny21
Oct 17, 2015 07:47 PM
Tigger Welder
Oct 1, 2015 08:41 AM
fortune46x
Sep 16, 2015 08:18 AM
