no torque wrench
Old Nov 24, 2010 | 06:32 PM
40series's Avatar
Default no torque wrench
i dont have a torque wrench and need to only torque some knock sensors to like 10-15 ftlb's i heard if your over do them there are crystals in there that can crush? is 15 ftlbs a little past snug?
Old Nov 24, 2010 | 07:16 PM
hirdlej's Avatar
Just snug is fine. Like putting in your oil drain plug
Old Nov 24, 2010 | 09:44 PM
00K1500's Avatar
Gotta fish scale? measure your wrench from center of the bolt to the end where you can hook the scale. Convert to feet. Take this number times 15 and thats how many pounds you need to pull the scale to to hit 15 ft/lbs. Make sure the scale stays parallel to the wrench as you pull.
Old Nov 24, 2010 | 11:00 PM
PathfinderJr's Avatar
This is all you need.
Old Nov 26, 2010 | 02:03 AM
budhayes3's Avatar
PT's Slowest Truck
Definitely just snug, but not loose. A knock sensor that is too tight will be over sensitive, and a loose knock sensor could rock around and give a false signal...
Old Nov 27, 2010 | 02:58 AM
I'm a huge fan of "snug." Been using it on my bikes for years while all my friends clamor over the torque specs for silly things like oil pan bolts, valve cover bolts, etc. Snug is definitely tight enough on things like that. It's all in the feel...
madmann26
Apr 29, 2020 09:17 AM
JordanH
Dec 25, 2015 08:32 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
g6t6o
Sep 26, 2015 10:57 AM
