No room to change plugs cause headers
Old Feb 27, 2012 | 03:55 PM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by 40series
I found some 3/8 " tubing which will work nice to get them started, some one also recommended using a open end wrench which sounds good too to breakm an snugem
Use vacuum hose, not 3/8" tubing. Needs to be small & flexible. Here's a pic, for an example.
Old Feb 27, 2012 | 04:07 PM
  #22
thunder550's Avatar
High on diesel fumes
Huh? You won't be able to grab the plug with an open end wrench. They make spark plug sockets specifically for this.
Old Feb 27, 2012 | 04:16 PM
  #23
Mangled03gmc's Avatar
Baltimore Whore
What in theee hell is the problem here? I take it you are on a very limited tool supply?
Old Feb 27, 2012 | 04:29 PM
  #24
40series's Avatar
Default Oh no man
Originally Posted by mangled03gmc
what in theee hell is the problem here? I take it you are on a very limited tool supply?
oh no man , i have plenty of tools idk what these guy are posting about,,, im letting the header bolts sit over night sprayed in pb blaster
i am hoping i have enough to grab hold to when the header comes off the broken bolt is in the front at least
Old Feb 27, 2012 | 04:32 PM
  #25
Baltimore Whore
Thats with a ratchet, 2'' extension. Nothing fancy. A swivel would make it even easier.
ARC
57
Feb 21, 2022 10:54 AM
Noah Burns
Sep 7, 2015 05:50 PM
rojeho
Aug 8, 2015 07:20 PM
mr03silverado
Jul 26, 2015 01:05 PM
