No right turn signal
Old Apr 29, 2020 | 04:01 PM
someotherguy's Avatar
Originally Posted by 64rcs
Correct. I have it hooked up the same as the turn signal that works.
I appreciate your help Richard.
Since the socket will fit either way, mirroring the side that works does not necessarily mean the polarity is correct on the other side.
Originally Posted by RB04Av
You don't necessarily have to have the resistors for that. They make flashers that are smarter and can handle it. I also have all LEDs for my exterior lighting; new housings in the rear, and replacement bulbs in the front; and a replacement flasher that works just fine without resistors. Like this one. https://www.amazon.com/Novita-LM487-.../dp/B001KS6GIG My OE flasher did the "hyper flash" thing you see the little fart-can imports doing all the time. For the same reason no doubt. I've heard of other fixes for this but have no idea whether they work or not.
The resistors aren't "in-line" electrically, although that's what it looks like from the way they hook up; they're actually in parallel with the lights. All they do is draw enough extra current to make the load look normal to the flasher that is expecting lots of light bulb current.
You DO however need resistors in the brake light circuit for the cruise to work right. I found that out the hard way. There might be some sort of tuning or something that can be done, a voltage threshold or the like on the brake light line that you could set, that would cure this. But apparently the LED bulbs don't pull the brake light line down to ground effectively enough for the cruise. It thinks the brakes are on all the time. I put ONE resistor in the brake light circuit and that made the voltage on the brake light line go low enough for the cruise to work again.
If one side of the truck works but not the other, I doubt it's a flasher problem, as such, since both sides use the same flasher. If your setup uses the OE sockets I'd suggest doing the simple thing and just turning around the way the plugs go into the bulb sockets, and see if it changes. LEDs are often polarized and require 12V to be specifically on one pin and ground on the other, and will not work if hooked up the other way.
A bunch of "correct!" in this post. However that Novita flasher seems to have gotten a bit expensive these days. You can hack the original flasher by cutting one leg on the timer IC on the circuit board; it's super easy to do. It will behave pretty much the same as the Novita flasher and you already own it, zero cost.
Some of the "full housing" replacement LED taillights don't require the addition of any resistors or a special flasher, as some have the resistors built-in on their circuit boards, making them plug-and-play.
I don't recall having trouble with my cruise until I installed an LED CHMSL. Then I added a 6ohm/50watt resistor up there (typical gold-colored finned aluminum heat sink style that most use in LED swap applications) and that fixed my cruise. For those that haven't done these yet; be sure to install them in an area where nothing nearby can be damaged as they get stupid hot when in use.
Richard
CaliSilverado
Feb 13, 2013 10:34 PM
ccantu0389
Jul 17, 2012 12:28 AM
2000silvrx81
Sep 10, 2009 07:24 PM
garrettpen
May 2, 2006 09:42 PM
Scream
Nov 10, 2004 02:59 PM
