No heat, help!
Old Jan 19, 2012 | 09:25 AM
B2E2RUN's Avatar
Default No heat, help!
I did a search, but couldn't find what i am looking for.
2000 Z71, 4.8L. I have no heat. The engine does get to operating temp. A few weeks ago I replaced the stat (stuck open), and refilled the system. Now, i think i have air in the heater core. When i accellerate, i hear "running water" through the core. The inlet hose to the core is hot, but the oulet is luke warm at best. I spoke to a buddy that owns a perf shop, he says that once the coolant system is opened, it must be "vacuumed" to eliminate the air in the heater core. I trust him, but surely there is an easier way! It is cold out, dammit! Am I the only one that has screwed this up?
Mucho Grassy-*** in advance!
Old Jan 19, 2012 | 10:12 AM
Robert91RS's Avatar
I have been able to cycle the air out with several heat cycles in the past but if its being stubborn you may need to rent a vacuum tool.
Old Jan 19, 2012 | 10:19 PM
Suburbazine's Avatar
If in is hot and out is not, you probably have a plugged core. If the blend door was stuck the out hose would be as hot as the in hose.
Old Jan 20, 2012 | 02:34 AM
CashDudeHomie's Avatar
I've drained and refilled many times and have never had air pocket problems. Maybe there is an obstruction.
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
11
Oct 27, 2015 03:38 PM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
Shotguntommy
Sep 15, 2015 05:24 AM
