No AC at idle on 2000 Silverado
no title here
I couldn't figure out the best section for this so I used this one. At idle my 2000 Silverado blows hot air. As you drive it gets ice cold. Could it be the clutch fan? I have f body fans and a harness but I twisted my ankle really bad and haven't been able to work on anything. Coolant temp never changes btw. Help its been almost 100 every day this week.
Check freon level, accurately. Then check to see whether the clutch on the compressor engages when you turn the a/c on. If it doesn't, you may have a bad switch, clutch, or a faulty compressor. Start with the cheap stuff and work your way from there. In other words, it may just be a bad switch or low freon, so don't replace your fans when it could be a much cheaper solution.
