new motor/trans about to drop in... quick question...
Old May 26, 2009 | 09:55 AM
silver-mod-o's Avatar
Hunt&Fisherator
Default new motor/trans about to drop in... quick question...
Dropping my Iron 347 and 4L80E back in over the next couple days.
Can I bolt the starter on the motor before it goes in? Never have in the past but I figured I'd still be able to get to the converter bolts without the dust cover on the 80E, and it would be easier this way than fighting the starter in over my turbo oil drain, seems I have "engineered" it right in the damn way
Just wondering if someone has ever tried it this way and ran into problems... Worst case scenario, ill have to take it back out...
Old May 26, 2009 | 10:05 AM
Dark Halo's Avatar
I will say the 80 will give you a little room on either side so it may be possible, but Im not 100% sure you will get away with it. I would try it at worse case you will have to take it off.
Old May 26, 2009 | 10:07 AM
JAVI05's Avatar
i did that one time and had to take it back down to wire it up.. it was on an older chevy there was no way in hell to wire it up without dropping it. dont know if that will be a problem for you but its a heads up.. good luck
Old May 26, 2009 | 10:10 AM
dlt76028's Avatar
i left the starter on when i put the engine and trans in as one piece.
Old May 26, 2009 | 10:16 AM
Hunt&Fisherator
Nah, I'm not going to put it all in at once... Motor, then trans... I've decided against dismantling my entire front end...
Old May 26, 2009 | 10:19 AM
dlt76028's Avatar
you dont have to take the front clip off, we did it without removing anything other then the radiator.
Old May 26, 2009 | 10:22 AM
Dark Halo's Avatar
Bringing up the wiring you may not be able to. The wires are fairly short and if you can not reach it bolted it will have to go on after.
Old May 26, 2009 | 10:37 AM
Hunt&Fisherator
Why wouldn't the wires reach the starter?? They've gotta reach it somehow?
Old May 26, 2009 | 10:48 AM
Dark Halo's Avatar
just saying you may not be able to reach the back of the starter when it is bolted up in order to install the 2 wires. You may have to keep the motor up some if you are going to try and install the starter first, and Im not sure the wires are long enough for that. Maybe my POS is just PITA
Old May 26, 2009 | 10:57 AM
dlt76028's Avatar
you can get to the starter from the top and reconnect it
