new build ramblings/questions
Old Dec 13, 2016 | 07:15 AM
El_Diablo's Avatar
Default new build ramblings/questions
I have a lot of brand new parts I never used left over from my old '06 Silverado that im going to put to use on another truck. (Crew cab 1/2 ton for my ol lady.) Ive had a grip of fun toys over the years and its time for her. Just a cool family hauler I can build out of things I already have.
Only major part Id have to buy is a torque converter. What torque converter/stall rpm would you use for a 2003-2006 4door halfton pickup?
5.3 engine/4l60 transmission
Cam specs- 231/240 .627/.607 115LSA
Stock weight/transmission/rear gear.
I want to keep the stall rpm within reason. This isnt a racetruck. Just time for her to have a badass cruiser!
Old Dec 13, 2016 | 08:01 AM
madmann26's Avatar
Well.
I'd be worried about PTV clearance with that cam. If you wan't a "cruiser", I'd get a cam with a 110-112 LSA. Chop chop at idle.
Old Dec 13, 2016 | 09:30 AM
Mark Johnson's Avatar
GM 300mm HP 4L60 LS Torque Converter model 3A
Circle D Specialties High Performance 300mm Torque Converter for GM 4L60 LS
That is quite a bit of cam.............
Old Dec 13, 2016 | 10:32 AM
El_Diablo's Avatar
Originally Posted by madmann26
Well.
Will verify ptv clearance and flycut if necessary. I have the cam on the shelf so Im using it. Good lookin out though.
Old Dec 13, 2016 | 04:25 PM
FFDP's Avatar
You're going to need larger fuel injectors too for that large of cam if the truck is not flex fuel.
Those little 24lb/hr injectors will be maxxed quick.
Old Dec 14, 2016 | 03:21 AM
El_Diablo's Avatar
No prob. I have a new box of injectors left over too that will be overkill for it.
Old Dec 14, 2016 | 03:25 AM
El_Diablo's Avatar
Without milling the heads what kinda power will a 5.3 make cam only with full exhaust/no cats? How much is left on the table compared to milling the heads?
