need tips for finding coolant leak
Old Feb 22, 2013 | 07:31 PM
40series's Avatar
Default need tips for finding coolant leak
cant find where this coolant is coming from. no where obvious it puddling on the cross member
Old Feb 22, 2013 | 09:36 PM
blown02408's Avatar
02 w/ lowest mileage 2800
Probably the rear seal on the water pump. There are no rebuild kits for them, you'll have to buy a new pump if that's the case.
Old Feb 22, 2013 | 09:40 PM
chevymec's Avatar
You can get some dye that turns the coolant neon green or get a pressure tester and a mirror.
Old Feb 22, 2013 | 09:54 PM
There is a weep hole drilled in the bottom of the water pump look for light pink staining around this hole. Look at the quick connect fittings on the heater core. Have someone pressure test the system and radiator cap to see if it will hold pressure. Do it dead cold and then hot.
Old Feb 23, 2013 | 12:17 PM
Gadgetized's Avatar
More than likely it is the water pump gaskets.
Old Feb 23, 2013 | 01:34 PM
Mangled03gmc's Avatar
Baltimore Whore
Yep, they are a pita to find because it is such a tiny leak.. Been there done that
Old Feb 24, 2013 | 01:51 PM
40series's Avatar
Default its the bearing seal
its the bearing seal,,,
Corvette454l88
Sep 1, 2016 01:24 AM
thewrx
Aug 12, 2015 08:28 PM
BIGD4504
Jul 28, 2015 11:46 AM
1320Chicken
Jul 14, 2015 10:58 PM
