need schooled on fuel injectors
Old Apr 16, 2012 | 05:41 PM
2000chevysilverado's Avatar
Default need schooled on fuel injectors
I'm in the middle of doin my tbss intake build with my spare intake I have came off a 03 3 bolt dbw throttle body on it I'm using the return style fuel rails and the injectors I pulled the numbers off the injectors and they are 32lb flex fuel injectors, so here's the question will these work for a 2000 style injector or do I need to get a differnt connector? The only reason I'm asking was these injectors were .20 longer than my stock injectors so I didn't have to modify the cross over tube just had to do some trimming on the intake and it all fit together. Plus I've wanted to get bigger injectors to help support other mods I will be doing 799 heads 215 218 cam plus the tbss intake and some giggle gas later on. Any info will help or any pics to help me.
Old Apr 16, 2012 | 07:03 PM
mcfarlnd's Avatar
Un-Registered User
I'm pretty sure the new injectors that you are going to use are EV6 connectors. So, yes you will need different connectors. What are the part numbers on your injectors?
Old Apr 16, 2012 | 07:13 PM
I will have to look tonight when I get home is there a adaptor
Old Apr 16, 2012 | 09:29 PM
batboy's Avatar
11 Second Club
The TBSS uses LS2 style injectors, right? If so, there ars adapters available. SLP makes an adapter (part number 12425).
Old Apr 16, 2012 | 10:04 PM
Yea uses a ls2 injector got those too just don't know if any good or not
Old Apr 17, 2012 | 10:26 AM
batboy's Avatar
11 Second Club
LS2 injectors flow about 32#. LS1 injectors are 28#. What are the 5.3? Maybe 26#?
Old Apr 17, 2012 | 11:41 AM
The 5.3 were 22.5 i believe so they wont keep up possibly
Old Apr 17, 2012 | 02:21 PM
mcfarlnd's Avatar
Un-Registered User
Depends on the part number. There are so many different damn injectors used on these motors, it's ridiculous.
Old Apr 17, 2012 | 10:29 PM
25326093 is the part number I get on the injector
This is what there looking like
Old Apr 18, 2012 | 10:29 PM
robert85's Avatar
MASS seller approved
looks like the uscar plug, also the same plug on the ev6 injector so get the adapters from fuelinjectionconnection.com I think it is. Good quality! Used them on mine. Just tried to go to the site to get you a part number and I guess the site is down at the moment! But the adapter is a minidelphi to uscar connector. Hope that helps!
