Need Pro A/C advice...
Old May 14, 2011 | 03:48 PM
Bill Reid's Avatar
Default Need Pro A/C advice...
OK, so I blew my hard line... the one that goes from the condensor to the orifice. I rubbed a hole in it with my braided stainless turbo cooling water line. I thought it was out of the way enough... wrong. Anyway, I replaced the line but the replacement from Chevy came with the other side of the connection that bolts to the firewall bulkhead fitting as well. I ASSume the reason was because the new pipe setup has a larger connection fitting where the orifice goes. So, I installed it as a set. The old setup had a high pressure fitting on the condensor side of the orifice... and a low pressure fitting on the other side of the orifice. New pipe setup from Chevy... I ASSume to be correct... has no low pressure fitting. So, how the heck do I fill the freon? Doesn't only go on the low pressure side? I'm afraid Chevy gave me the wrong hard pipe. Is there an easy fix for this?... like a hose in another location that has the low pressure fitting?
Thanks,
Bill
Old May 14, 2011 | 04:13 PM
Robert91RS's Avatar
Vin number?
Old May 14, 2011 | 04:25 PM
Robert91RS's Avatar
Sounds like they sold you part number 15784599 and should have sold you #15785056.
Old May 14, 2011 | 04:33 PM
Bill Reid's Avatar
15784599 is what I bought... and it shows as the only option for my truck according to GM Service Information. I PM'd you my VIN... sounds like thats the only way to get to bottom of this.
Old May 14, 2011 | 04:35 PM
Robert91RS's Avatar
PM replied. GMs catalog can be less then user friendly at times but that other number should get you back on the road.
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
Hpinnovate
Sep 4, 2015 02:28 AM
