need help with overheating quick guys
Old Aug 20, 2011 | 02:43 PM
726.0chevelle's Avatar
13 Second Truck Club
Default need help with overheating quick guys
Ok my truck cools fine when driving but when I stop in traffic the temp climbs up within 5 minutes. I have a 99 ecsb with a lq4 and i have the 06 electric fans and a new 34 inch radiator. The fans are turning the right way and are running strong. And a few weeks ago I cleaned the condensor so there is little restiction there. I have the fans hooked up on a thermostat so basically they turn on and stay on I just installed a new thermostat so Ill see if that works. The only thing i can think is I have air still in the system. I have been trying to bleed air with little or no luck. Hows the best way to bleed the lines?
Old Aug 22, 2011 | 12:28 PM
budhayes3's Avatar
PT's Slowest Truck
Are you sure that the fans are turning in the right direction? if not, the polarity of the plugs need to be reversed. As for bleeding, I always grab the upper hose while filling with coolant, and pull it toward the ground and hold it that way as air bubbles into the reservoir. I squeeze it as I'm pulling it downward, and can feel and hear the air escaping. Repeat the process multiple times until I can no longer feel or hear the air bubbling. I've done this same procedure a gazillion times, on both trucks like ours and other manufacturer's vehicles which are prone to air pockets, and have always had success.
Old Aug 22, 2011 | 02:00 PM
Chevy-Fun's Avatar
I will have try this. Been having same prob after 5-10min starts gettin hot at stand still. Fans wrk n right direction. I was just blaming the Tx heat 105-110* thanks for the post
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
