mpg question
Old May 6, 2009 | 04:23 PM
chevyz7120's Avatar
here are some pix of what my TB looks like
its pretty damn black in there
http://www.texastruckscene.com/pictu...&pictureid=856
http://www.texastruckscene.com/pictu...&pictureid=855
Old May 6, 2009 | 04:38 PM
SilverDog's Avatar
I just recently took off my dad's TB on his 2000 silverado with 40k on it and it was pretty dirty. Looked alot like your TB from the outside but once you look inside you will be amazed by how dirty it is. It was nothing compared to my 2004 silverado with 55k. I'm guessing if you look inside the manifold you will probably see a puddly of oil sitting on the bottom of the manifold from the PCV system. As for achieving good MPG-slow takeoffs, regular maintenance, and good tune.
Old May 6, 2009 | 04:40 PM
chevyz7120's Avatar
so just go get some TB cleaner and go from there?
Old May 6, 2009 | 04:54 PM
SilverDog's Avatar
Definitely take your TB off and EGR system off the manifold (only one bolt, and be careful not to bend the EGR tubing to much) and try to clean the inside of the manifold as much as you can. This might be overkill. But if you go so far you might as well go farther and do the job completely.
Old May 6, 2009 | 08:54 PM
TX Tahoe Z71's Avatar
While it's off, you should get a throttle body spacer too
Old May 6, 2009 | 09:25 PM
viciousknid's Avatar
Where's the Beef?
After you do all of that get a tune.
i'm getting 16-17mpg with my 5.3 ECSB with mods in sig.
I can do better than 17 if I stop leaving for work late.
Old May 6, 2009 | 11:44 PM
chevyz7120's Avatar
i just sprayed the valve and open the valve and sprayed all inside and let it soak til it dissolved and closed da valve started it up
it bogged off the start but almost immediately returned to perfect idle and ever since then idles just right and i got my throttle response back and i can definately notice the difference
i used b-12 chemtool throttle body cleaner from autozone-costs 3 bucks for a 160z can of it
chevyz7120's Avatar
16oz i mean**
blownss27
Aug 14, 2020 08:27 AM
gaps
Oct 15, 2015 02:53 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
