This might sound flaky,but...
Old Jul 13, 2006 | 09:05 PM
shandy294's Avatar
Default This might sound flaky,but...
...has anyone tried running e-fans off AC from a DC-AC converter? I was wondering because you could use low-amperage fans (and avoid going to a larger alternator).
Instead of having to provide 30 to 40 amps at 12Vdc,you could use 3 to 4 amp ones running on 120Vac. Also,although there are zillions of AC fans,are there any that would fit?
Just kind of wondering,at this stage.
Old Jul 13, 2006 | 09:26 PM
dewmanshu's Avatar
Moderately Differentiated
energy is a funny thing. If we could just figure out how to get an engine to run itself once the initial power is used to get it started!
On its simplest terms, you still have to feed the converter with DC power. So on the ac side you might be low on amperage draw for that particular voltage and ac/dc setting, but you still need to mathematically feed the converter with the required energy of the dc. Back to where you started.
277volts AC 10amps is (for arguments sake) 20amps on 120voltAC. Why doesn't houses use transformers to cut the amperage in half? Because you still need to feed the "line" or "power" side before you step it down or up. Make sense? You actcually have some energy lost inthe transformation as well.
disclaimer;I wasn't being mathematically accurate, just using vague comparisons.
Old Jul 14, 2006 | 06:17 AM
PSM's Avatar
PSM
Ya energy in = energy out
volts* amps = watts AC or DC
and with inverters you lose energy in the form of heat.
so in a perfect world an dc-ac inverter would do say 12vdc @20 amps = 120vac @ 2amps, but alas we do not live in a perfect world
Old Jul 14, 2006 | 11:32 AM
shandy294's Avatar
Ill conceived by me. Later-on I was thinking about Pout=Pin...and how to control the coverter off/on cycling. Probably more trouble than it's worth.
lukn4trbl355
Oct 21, 2015 11:19 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Rockrz
Sep 29, 2015 09:07 AM
