Metal Shavings
Old Oct 2, 2011 | 06:51 PM
aQuickLS1's Avatar
Default Metal Shavings
Well, last night I noticed the truck was idleing a little rough. And when I accelerated a knocking sound increased. At first I thought it was just an exhaust leak. I changed the oil and noticed a bunch of tiny metal shavings on top of my oil pan/bucket. I also could not find any exhaust leaks. The sound seems to be coming from the bottom rear near the passanger side. Any ideas? Oil pressure is normal.
Old Oct 2, 2011 | 07:14 PM
guero68's Avatar
I had the same symptoms...Had fine metal shaving in oil. Just went ahead a did a swap. i pulled the heads all cylinder wall look good. Connection rods dont have any blueing..going to take out the crank and pistions to see whats up but i can see anything as of now...
What year is your truck and mileage..mine 08 13500mi
Old Oct 2, 2011 | 07:52 PM
aQuickLS1's Avatar
The truck is an 06 5.3 with 121k on the clock. The trans has been slipping for a while, and I just bought a built 4l65e. I was looking foward to the truck running good again. The truck drives fine, just makes that sound. It does still sounds like an exhaust leak along with a dull knocking sound. I've also have a kenne bell s/c thats been waiting to be installed as soon as the trans was replaced. Bumbed!
Old Oct 3, 2011 | 05:05 AM
06Sierra2's Avatar
do you have a picture of the metal shavings you found?
Old Oct 3, 2011 | 07:30 AM
aQuickLS1's Avatar
No pictures. They were small particles. I could run my finger on top of my oil drain pan and see the particles on my finger. I will see if i can get some pictures tonight.
Choda
Jun 5, 2025 06:43 PM
Closer_2001
Sep 16, 2015 11:46 AM
lsxperformance
Sep 14, 2015 10:53 AM
94f150
Sep 13, 2015 06:39 PM
bisqikss
Sep 8, 2015 03:35 AM
