manifold removal
manifold removal
do you nee dto take the fuel rail off the manifold to remove the manif.- i read you dont , just disconnect the injector
Well it is really hard for me to read your post but I think you're asking about the intake manifold removal?
If so, disconnect the injector pigtails, and disconnect the fuel line coming into the fuel rail. Leaving the fuel rail in place and not disturbing the injectors. It will all lift off as an assembly with the intake.
well it is really hard for me to read your post but i think you're asking about the intake manifold removal?
The electrical connectors on the injectors can be a little tricky and the quick connect on the fuel line needs the right tool to do the job. But I don't think it's a tough job at all. I can't quote you a time frame but it doesn't take long at all to pull one off.
funny thing is.........
CLEANING THE PORTS AND AROUND THEM AND NOT GETTING ANY GUNK DOWN IN THE ENGINE WOULD JES BE MY LUCK
Yeah just take your time, vacuum everything around the intake before you pull it and after you pull it. Stick some rags or paper towels or tape off the intake ports as soon as you can. Nothing sucks more than dropping **** down the intake runners and into the cylinder. That would make an easy job, not so easy.
69z-28
09-21-2015 07:31 AM
LSX-81-SIERRA
09-05-2015 02:51 PM
