maf plug , anyone??
Old Dec 4, 2006 | 05:46 PM
2004SSS's Avatar
Default maf plug , anyone??
im trying to get plug for my maf, the make part so i can extend the wires from my original maf wihtout cutting them. the maf has the plug built in so i dont know where to get this. does anyone have any idea of where a plug might be found or where i would get them? i need a make and a female plug.
Old Dec 4, 2006 | 05:49 PM
thunder550's Avatar
High on diesel fumes
Might check with Speartech, but I doubt you'll find much....what's wrong with cutting and extending the wires?
Old Dec 4, 2006 | 08:33 PM
kbracing96's Avatar
No buddy makes a female end like the MAF has, you can actually move the MAF a lot just buy cutting the wires out of the lume. I moved mine to the drivers side front of the motor without cutting the wires.
Old Dec 5, 2006 | 12:03 PM
shandy294's Avatar
What kb said is a good idea. If it's not long enough you can cut it somewhere in the middle and splice in new wiring. You should solder or butt splice/quick disconnect and put shrink tubing over each connection and a larger piece of shrink tubing over the whole spliced area.
Old Dec 5, 2006 | 12:25 PM
kbracing96's Avatar
Here is a pic of where I moved mine to without cutting any wires.
Old Dec 5, 2006 | 02:40 PM
budhayes3's Avatar
PT's Slowest Truck
You can probably get it at your local dealership's parts dept or a salvage yard...
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
