LS6 Intake on 5.3
Old Sep 10, 2006 | 07:12 AM
Sport Side's Avatar
Kano gained 2.5mph, with similar track conditions. Not to mention, it dropped him down a tenth to the 60' and he had to come out of the hole off idle as opposed to before, where he would stall the converter up.
Reaper with his H/C 5.3L, said to me after the swap, "It feels like I gained 50HP at every RPM."
BlackSheep also had tremendous gains back in the day.
Then, you have the countless dyno graphs that flatline at 5500-5900RPM, meaning no more power gain. The LS6 intake can make peak HP at 6200-6400 RPM.
I guess once BlueCajun starts running 12.2s in his cammed 5.3L, some of you might realizing that the truck intake is a restriction.
Old Sep 10, 2006 | 08:52 AM
tdrumm's Avatar
Flatlining at 5200 here
Old Sep 10, 2006 | 09:16 AM
ZR1 DREAMING's Avatar
mine is right there too, maybe a hair higher. there is no question that with only a cam any of the LS6 style intakes would gain over the truck manifold.
Old Sep 10, 2006 | 09:50 AM
speedy02's Avatar
Truck intake= junk..lol
Old Sep 10, 2006 | 10:10 AM
closet red neck's Avatar
Originally Posted by DLH2006
To be honest like stated above it really isnt worth it! Considering the other parts required to do the swap. But im sure you wont lose a noticeable difference except on paper, if you have a stall. The stock manifolds have made some quite impressive time slips here so in other words dont fix it if it aint broken. You should just sell the LS6 intake on ls1tech, but if your still wanting to do the swap do a search and you will find some good info.
Well for starters, I do have a stall(3800 in my sig) but I did a search on here and thats my problem!!! Too much info and now about the whole thing!! I was going to start the mods in October(after the wifes B-day on the 26th) and get this thing rolling.
Thanks, James
Old Sep 10, 2006 | 10:18 AM
Originally Posted by dirt_track_racer_81
on my truck it would start to level off at 6300 but still make power to around 6700, that was on my 5.3 with tr224 but if your goin with heads and cam, id say it prolly would be beneficial
I think so too......but on the same token, in order to benifit from a LS6 intake, I think you would have to do all the mods to make power lets say from 5600rpm to 6500rpm and stop @ 6500rpm if you desire. I was just alittle nervous because they way some people on here were talking like you had to spin this thing min:6000rpm-max:7200rpm. I don't want to do this. 6500rpm will do it for me. But thank you for your insight!!
James
Old Sep 10, 2006 | 10:21 AM
Originally Posted by bluecajun5.3
it's worth it.
my hp flatlines @ 6k, also many others with 5.3's with similar mods are experiencing the same thing.
we'll see if it's worth it in 3 or 4 months from now.
I'll beat you @ the punch!!LOL
James
Old Sep 10, 2006 | 10:26 AM
Originally Posted by Blown02Sierra
by internals do you mean just valvesprings, or will the rockers / pistons / connecting rods take a ****?
I'm mean the rod bolts mainly but everything else that is in the main engine(i.e.crank, rods, rod bolts.........the parts that are inside the block). Some people on here run the **** out of their engines but I'm not going to go this route. I'm scared!!LOL!! Shut up Cody!!!!
James
Old Sep 10, 2006 | 11:48 AM
dirt track racer 81's Avatar
James
my rods bolts lasted goin to 6800 everday..just the pistons couldnt handle it
Old Sep 10, 2006 | 01:06 PM
Okie5.3's Avatar
hoping to have mine on next month, along with heads and maybe that TSP bumpstick.
