LS3 Into 2003 Z71 Tahoe
Old Dec 21, 2019 | 11:26 AM
wretched73's Avatar
Originally Posted by reath1
Just trying to keep this as simple and quick as possible.
Then you can still run your stock 5.3 intake, but performance will suffer
Old Dec 21, 2019 | 11:30 AM
reath1's Avatar
Not at all worried about the small loss on the intake. It might help keep me from destroying the 4L60e so quickly.
Old Dec 21, 2019 | 12:44 PM
stroker87's Avatar
as for what brands you can pick from Caspers, PSI or Racetronix, I've used stuff from all 3 of them and had good luck
if your trying to save your 60e id put a BIG trans cooler then install a stop behind your go peddle, then prey to the performance gods! maybe you'll be one of the blessed few that has a golden 4l60e lol
Old Dec 21, 2019 | 12:48 PM
reath1's Avatar
Huge trans cooler was installed at about 30k miles. Has 130k on it now. Fluids maintained regularly. Hoping she holds together.
Old Dec 22, 2019 | 07:51 AM
reath1's Avatar
Bump.
Old Dec 22, 2019 | 12:53 PM
arthursc2's Avatar
What are you bumping for? We told you everything lol
the NNBS intake is a bolt on affair and offers 25hp/15tq (ish), silly not to do it IMO
you need a truck balancer, didn't see that answered for you already
Old Dec 22, 2019 | 03:57 PM
madmann26's Avatar
It won’t.
Old Dec 22, 2019 | 04:16 PM
stroker87's Avatar
i have some truck balances around here some place, if you need one cover shipping and ill send you one there from 6.0's but all the same
Old Feb 13, 2020 | 11:24 PM
Rmrod15's Avatar
I’m sort of in the same boat as you, I’m in the process of swaping a complete 2012 LS3 into my 2005 yukon Denali.
I ordered the Linghnfelter 24x 58x Convertor box
and the knock sensor, crank, cam, and fuel injector conversion harnesses from Wiring specialties . Com
Other then that I’m going to be using the stick harness and also a ict throttle body adapter to run my stock TB on the LS3 intake manifold.
bad cutt
Jun 7, 2014 10:12 PM
ChadGilbeaux
Mar 21, 2012 06:13 PM
whyt00
May 27, 2011 08:01 PM
