lq4 and lq9 differences?
what is the difference? i know one is better for a forced induction.. i'm plannin on a magnacharger or sts turbo when i do the 6.0 along with a 75 shot or so.. which should i go with?
Originally Posted by Quik
LQ9 internals are different then the LQ4 the LQ9 is a built factory motor with flat top pistons were as a LQ4 is your typical motor
LQ9 and LS2 have same internals
The LQ9 rods are beefier than the LQ4's. The LQ4 has dished pistons and lower compression. It'll be better for a boosted application. Should be cheaper than a LQ9 as well.
the LQ9 with LQ4 pistons would be ideal for boost and if you went with a thicker head gasket then stock you would be around 9.1 CR which is pimp and have a stout bottom end
Originally Posted by OKLAGMCRUISER
when in your timeline are you planning this swap, JJ?
