Long Term Budget Engine Build
Old Aug 25, 2010 | 02:58 PM
cali92rs's Avatar
Default Long Term Budget Engine Build
I am getting a little bit tired of my 5.3L and am looking for a project to occupy myself. I am getting married real soon and after that more than likely a kid. Soooooo, that means this will have to be a budget build and reliable. The truck will remain my DD. I am looking to maintain low-end torque, but would also like to increase my freeway merging speeds. I am not gonna be spinning this thing past 6000.
I am thinking of getting a 5.3L bare block as cheaply as possible, machining for a 383 stroker bottom end, then on top going with something like the TSP Stg 2.5 5.3L Heads/224 Cam and my stock intake.
What do you think? I was thinking that a 5.3 could be had so cheap, and because I am not looking to drag race, not going too big with the cam.
Old Aug 25, 2010 | 05:53 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like a nice build, as you mentioned, the block will be cheap, but the rotating assembly will cost a little bit. You mentioned not spinning past 6k, but I think that that cam will probably pull a bit past 6k, even in 383 cubes...not much, but a bit...
Old Aug 25, 2010 | 10:35 PM
brent5631's Avatar
You say that. But then you find that there is a lot of fun past 6k!
Old Aug 26, 2010 | 01:29 AM
pewterliftedz's Avatar
i think more budget minded would be to build a lq4 short block with heads and a small cam 212/218 comes to mind.
Old Aug 26, 2010 | 01:05 PM
cali92rs's Avatar
That is very true, in fact I keep going back and forth between getting a 5.3 or 6.0, because a 6.0 is only a couple hundred bucks more and the rotating assemblies for the 383 and 402 cost the same...
It sux being a hotrodder and not being rich
ARC
57
Feb 21, 2022 10:54 AM
USMCvet0311
Aug 14, 2015 10:28 PM
therock
Jul 25, 2015 09:23 AM
Ammadien
Jul 22, 2015 08:50 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
