?? on line lock with abs
Old Oct 24, 2005 | 10:03 PM
Mangled03gmc's Avatar
Baltimore Whore
Default ?? on line lock with abs
I have not looked into this but has any of you guys with line locks hadproblems doing the burn out with the abs system. Not that I have a drag truck but do like to smoke the hides sometimes. any info would help. Thanks
Old Oct 25, 2005 | 09:02 AM
Fogle07's Avatar
i know you can do it. try searching over on ls1tech and see how they done it to their cars. would be pretty much the same setup
Old Oct 25, 2005 | 10:08 AM
OBXMarine's Avatar
One of our fellow truckers has done it. I believe he installed it backwards in order to bypass the ABS.
Old Oct 25, 2005 | 02:00 PM
negativeswitches's Avatar
unless you do a HUGE burnout it shouldent effect it, best way to do it on an auto IMO is install it in the rear after the abs backwards so you have to hold the brake to do a burnout still but it locks out the rear wheels
Old Oct 25, 2005 | 05:18 PM
Wilde Racing's Avatar
How do I change this text
Thats how I have mine
Old Oct 25, 2005 | 05:35 PM
Baltimore Whore
Ok thanks thats the way I will probably do it. I wouldn't worry about it but lately I have had the urge and don't want to screw the back brakes up. Thanks
Old Oct 25, 2005 | 05:52 PM
the back brakes are about useless on my 99 horrible engineering from gm they have about 1/2 the contact area of what they should be, i dread the day if my front brakes go out
Idryfly5
Sep 2, 2022 08:55 PM
carid
Oct 28, 2015 08:24 AM
dselby25
Sep 11, 2015 05:03 AM
97aztecgt
Sep 10, 2015 05:07 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
