Largest TB on stock intake?
So what is the largest diameter Tb that will fit or work on a stock manifold?
I have the 5.3l if that makes a difference.
Thought all the trucks from 4.8l, 5.3l, 6.0l had the same intake. Correct me if I'm wrong.
What is the stock opening on our manifolds?
Can the stock TB be opened up for any kind of gains in an FI set up?
Originally Posted by v8
alot of people PP there t/b, i run a bbk with it bolted to the manifold with out the spacer, well i use a 1/8" plate i made myself with the same 80mm opening.
Any other info an how much a stock TB could be bored out?
Is the stock TB 80mm matching the manifold?????
17,16,15,14,13,12,11 Drvr
the stock tb is 75mm, not sure on the intake mm size but like i said i did at one time have the bbk mounted straight to the manifold,but it would have very high idle so i built a 1/8" plate to help the air flow.
you cant bore out your tb but a bigger tb wont help you that much unless you realy need that much air like for turbos and blowers. but if you want one "Fast" has a good 90mm tb
http://www.litewarehouse.com/catalog....php?cPath=120
