Knocking Noise
Old Nov 20, 2006 | 09:57 AM
Big Tap's Avatar
Default Knocking Noise
I have an '02 Tahoe with the 5.3 and have a knocking noise coming from my engine on start-ups when it has been sitting overnight or for an extended amount of time (6-7 hours). It happens when it is warm or cool out, but seems a bit louder when it's a bit cooler out. It usually lasts for only 30-45 seconds and then goes away. My initial thought is that most of the engine oil has drained back down into the pan and it is having to re-lubricate itself, but I've never experienced this with my other rides.
Any ideas?
Old Nov 20, 2006 | 10:28 AM
spitfire2332's Avatar
sounds like the typical piston slap. Its a common problem with these trucks, nothing to really worry about.
Old Nov 20, 2006 | 09:27 PM
My previous 2000 5.3L Silverado didn't start do that until it had 115,000mi.
But it did the same exact thing as you described.
It didn't run any weaker though. It may have started to burn a quart of oil between my 5000 mi oil changes when that knocking began.
It never spit out any blue smoke though.
Put some full synthetic oil in it, and keep going!
Jim
Old Nov 20, 2006 | 10:25 PM
Daftearl's Avatar
I started using Mobil1 and Ive noticed that my piston slap has almost dissapeared. I actually forgot all about it until my serp-belt started squeking and then I was like, whoa, I dont hear that tick! Then I was like, damn, squeky belt. WD-40 hooked that up.
Old Nov 21, 2006 | 12:15 AM
Big Tap's Avatar
Yeah, mine just turned 117K. Good to hear that others have had similar experiences. I have considered an oil additive or switching to a synthetic. One person said Mobile1, any other suggestions?
Old Nov 21, 2006 | 12:17 AM
mine was at 13k, i was pretty worried, but then I heard about the piston slap thing. Crazy that you guys went so many miles w/o hearing it
Old Nov 21, 2006 | 12:20 AM
TXsilverado's Avatar
my truck has done it since i got it at 23,000 miles. no biggy, just dont go stomping it around until it warms up some.
Old Nov 21, 2006 | 12:31 AM
Blown02Sierra's Avatar
I've been getting it since 70,000. I thought it was a rocker goin out. I've been running mobil1 full synthetic since 60,000.
Old Nov 21, 2006 | 07:29 AM
silver-mod-o's Avatar
Hunt&Fisherator
sounds perfectly normal.... I had some disgusting piston slap his morning when I started my ****... it was 34 outside when I left for work!!!!!! damn I need to go back to Tx.
Old Nov 21, 2006 | 11:08 AM
redwagon's Avatar
different oil dosen't affect mine. i've been running mobil 1 for the last 10 oil changes and it still knocks with the best of them.
