Keeping up with maintenance 2007 RST
Old Jun 3, 2013 | 11:34 PM
1SiCkRsT's Avatar
Default Keeping up with maintenance 2007 RST
Well guys, I'm taking a trip in my truck in July. This will be first time I take my truck out long distance since adding some upgrades. This is what's done to it:
224/230 custom grind cam
Pushrods and PRC dual gold springs
LT headers and catless Y pipe
K&N intake
Borla X-R1 muffler
Circle D 3200 stall
Corvette servo
Transgo HD2
Dyno Tune
Pretty much all I can think off the top of my head. The truck currently has 46xxx miles. Coolant was changed about 10k miles ago (all hoses appear fine,normal temps) oil change is done regularly according to schedule(oil pressure is fine) easy starting and good voltage reading. Battery replaced about 5k miles ago. Transmission fluid is fresh also changed about 10k miles ago. Tires will need replacing so i'm on that already.
Pretty much I'm looking for any insight I can get on what else is time to
swap out or inspect. I'll be taking my family so it would really suck to be stranded somewhere. I appreciate the help.
Thanks.
Old Jun 4, 2013 | 07:23 AM
Slammed96's Avatar
Sounds like it should be just fine to take on a trip. About the only things I would double check before you go are the shocks (recommended to replace every 50k miles) and your brakes. If both of those look good, I would say you should be about golden.
chopperloco
Sep 28, 2015 08:40 AM
Orlerr
Sep 21, 2015 08:32 PM
supershift67
Sep 18, 2015 08:21 PM
RONIN LSX
Sep 5, 2015 10:55 AM
the owl
Sep 4, 2015 04:09 PM
