K&N arguement
Old Jan 19, 2007 | 07:29 AM
budhayes3's Avatar
PT's Slowest Truck
Even the nation's top tech can have a problem with an air filter that you have to oil, it's just the nature of the filter. I highly doubt that the filter and/or CAI ruined his engine, unless of course, as mentioned, the MAF got contaminated and sent a false reading to the PCM which in return incorrectly adjusted the A/F ratio. If that's the case, then the oiled filter could be the root cause of the issue.
Old Jan 19, 2007 | 07:30 AM
ss64impala's Avatar
just for the record being a certified technician dont mean ****. if he was a real mechanic he would quit bitching and fix it.
Old Jan 19, 2007 | 11:14 AM
LARRY01Z28's Avatar
thats what i was thinking. hell its blown up, cool. now time for a bigger better motor
Old Jan 19, 2007 | 12:31 PM
negativeswitches's Avatar
oh he located and swapped out the motor the next day, he wasent even REALLY mad about it just wanted to see if anyone else had a problem with it
motor was bone stock except for the filter
Old Jan 19, 2007 | 01:22 PM
99/5.3w/hips's Avatar
Is it possible that he OVER oiled it? I've heard of that causing problems with the MAF and making the engine run lean as ****. I've only heard of it happening on a few imports though and one truck.
Old Jan 19, 2007 | 04:45 PM
shandy294's Avatar
I had a drop-in in a 1.5L Civic for many (50K or so) miles and it always ran the same(small SOTP increase).
My intake has been on for about 20K so far...no problems.
Old Jan 19, 2007 | 06:10 PM
o2man98's Avatar
If he is working around dust and concrete the wet guaze filters are the ones NOT to have. Very poor fine contaminent filtration. I would be curious at seeing an oil analysis of his oil in those conditions. I would bet that the Silicon is SKY HIGH.
Take a look at the chart on this page to see how these oiled filters compare to even the cellulose paper OEM filters. http://www.amsoil.com/storefront/eaa.aspx?zo=1436102
Old Jan 19, 2007 | 11:31 PM
Zick's Avatar
What exactly went wrong on the engine and what proof does he have that the K&N caused it?
I personally don't care for them because of the fact that they do filter less and it doesn't justify the cost and risk of using it. Why risk letting extra dirt through and get less than 5hp from it???
All I've ever noticed from the kits was extra noise.
Old Jan 19, 2007 | 11:53 PM
i'm not sure beyond what i stated above
and i'm not going to restart the conversation about it to find out lol
i'm with you tho i'd rather have the quality air over the noise
Old Jan 20, 2007 | 12:00 AM
Turbo-T's Avatar
Thumbs down filter K&N
[SIZE=2][COLOR=Red][B] If that idiot put to much oil on his filter yes he will have problems. He can contact K&N and they can show him all vehicles listed with 100000 plus mile under bad conditions that never had compression problems.
