Injector question
Old Oct 15, 2005 | 09:01 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Injector question
I was told by the person who tuned my truck that...I should get Ford 42# injectors to upgrade. The reason...Ford uses a lower rail pressure, something in the 43-44 PSI range so when you plug their injectors into a GM fuel rail at 58-60 PSI they flow higher. Higher as in 45-48lb/hr. Also told the will fit just fine. Ebay sellers seem to agree on the fit but they weren't sure about the higher flow rates. Will this burn them up faster? I will need adapter no matter what injector I get because I have the flex fuel truck and the clips are different than most GM/Chevy trucks so this is not an issue for me. Opinions?
Read "Product Details" in the link below.
http://cgi.ebay.com/ebaymotors/42LB-...07486403QQrdZ1
Old Oct 15, 2005 | 09:43 PM
L-EATER's Avatar
11 Second Truck Club
I have them in both my trucks and they support have supported over 500 supercharged RWHP although with my current dry N20 system they are showing their inadequacies. I am going to pull them out soon and go with some bigger ones.
It depends on your combo if they will be right for you, but I have had excellent results with them.
Old Oct 15, 2005 | 10:05 PM
BlownChevy's Avatar
blownerator
25 Year Member
if you do that you will run out of fuel pump fast....I would suggest looking into a replacement pump......The Flex Fuel trucks have enough fuel pump for about what the Radix adds.....and I am not sure it is serviceable.
I hate Flex Fuel !
Old Oct 15, 2005 | 10:08 PM
1SlowHoe's Avatar
I was looking at that during the dyno tune. At WOT my fuel pressure dropped only once from 64 to about 62 and that was at 5600+ rpms. Would an inline pump do the trick or do I have to get into the fuel tank and upgrade to a bigger one? The bigger injectors along with a wet 50 shot would require what size pump? Can I go to big?
EDIT: The tuner had 60lb's for sale but he thought that would be overkill for my set-up.
EDIT2: How about one of these? Kenne Bell Boost-A-Pump
Old Oct 15, 2005 | 10:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
MagnaVolt
www.magnacharger.com
Old Oct 15, 2005 | 11:03 PM
1SlowHoe's Avatar
Sounds good. Just how "easy" is it to install? Says it comes with a harness. And of course how much? You think this will support 44-60lb injectors and solve my problem? PM me if you can't give the price, but you are a sponsor now....
Old Oct 16, 2005 | 05:38 PM
1SlowHoe's Avatar
ttt for BlownChevy-Magnavolt, how much?
Old Oct 16, 2005 | 05:56 PM
Typhoon#1600's Avatar
I have seen those injectors (FORD) used in many GM applications. I am currently using Delphi 50#ers in my Typhoon, as are many other Syclone/Typhoon owners, and they work great. I sell these injectors for $45/each shipped and insured all day long. I also have some 75# low-impedance injectors available (only 8 left) for the same price. I have sold over 100 of the 50's this year alone to the SyTy community, and everyone has been real pleased. These have all been flow-matched and are ready to go. They are rated at good for 100HP/injector.
Old Oct 17, 2005 | 08:59 PM
1SlowHoe's Avatar
So, I'm 99% sure I'm going to go with the 42# Ford injectors and I have a Magnuson Fuel pump booster on the way. As the truck sits now it tries to run lean around 5600rpm and the injectors are at 128%. I don't want the voltage booster to stay on, or come on, when not needed. I am looking at Hobbs style switches that come on at a certain boost level. I am thinking 5lbs would be a good guess. I never dropped fuel pressure during my dyno tune but with the new bigger injectors I am told I will lose pressure. The switch is adjustable from 4-15psi. I go into boost several times a day. Usually around 3 or 4 pounds, just normal driving.
My question is...What psi should I have the fuel pump voltage booster kick in?
Old Oct 17, 2005 | 09:10 PM
I've got the 8.1L marine injectors (43lb) and the same inline fuel pump that radix uses and have no problems with fuel pressure at all. I'm pushing well over 400rwhp
