I'm gonna buy it! Advice
Old Feb 2, 2005 | 11:26 PM
CashDudeHomie's Avatar
Make sure you get the right bearings. They changed in 99 but most places will still try to give you the old style bearings. I took mine to the parts store and they said they matched up to some 12 bolt bearings they had. 2 years later and all is still well.
Old Feb 3, 2005 | 12:08 AM
Kano's Avatar
Originally Posted by 6gear
If both carriers were the same width between bearing flanges and the ring gear surfaces were in the same relationship then you could use the same shims. That is not going to happen so you will need some shims to get the right fit and backlash
when i changed mine
my first readings averaged .0055
thru 5 readings
and when I put in the Eaton with the same shims
as stock
I hit .0055 straight up 4 times
good enough for me
I would have some shims though and double check everything
just to be sure
Old Feb 3, 2005 | 07:41 AM
6gear's Avatar
Originally Posted by gamedawgx53
when i changed mine
thru 5 readings
as stock
good enough for me
just to be sure
Then you are one of the lucky ones, but you did check before and after and that is what tells the story, to do the swap and not check backlash is a mistake. Usually backlash runs from .008 to .012 but since yours was running with .0055 backlash then you did fine.
gaps
Oct 15, 2015 02:53 PM
JordanH
Sep 12, 2015 12:02 AM
mayko
Sep 7, 2015 12:24 PM
1slomax
Sep 1, 2015 11:05 PM
