ignition stuck in lock position
the key will not budge in the ignition. the steering wheel is not locked, and the gear shift is not the culprit either.
i also disconnected/reconnected my battery to try to see if it was the pcm/ecm with no such luck.
before i go throwing time and money at it i figured i would see if you guys knew or had similar problems...
Cammed4ever
Sep 30, 2015 03:38 PM
