ignition stuck in lock position
Old Nov 17, 2008 | 08:43 AM
AGRV8D's Avatar
Default ignition stuck in lock position
the key will not budge in the ignition. the steering wheel is not locked, and the gear shift is not the culprit either.
i also disconnected/reconnected my battery to try to see if it was the pcm/ecm with no such luck.
before i go throwing time and money at it i figured i would see if you guys knew or had similar problems...
Old Nov 17, 2008 | 10:23 AM
wastedrubber's Avatar
seems almost insulting to say, but are you sure you have the right key? my room mate had the same issue with his truck a while back, then he gave me my keys back and got his own...
Alco
Jul 20, 2016 04:53 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
JoshH
Sep 28, 2015 11:19 AM
