if my studies are correct...
Old Aug 19, 2009 | 08:55 AM
chevrolet all the way's Avatar
Default if my studies are correct...
wouldnt these wheels sit about right for me as far as backspace/ offset and be perfect for mounting some slicks on. i am planning on grinding the calipers already.
http://www.summitracing.com/parts/CRR-3975860P/
plus for $40 a side thats perfect
Old Aug 19, 2009 | 09:30 AM
LowBlack99's Avatar
I mounted mine on stock steel wheel and painted them black. M/T et streets come in 16in diameters.
Old Aug 19, 2009 | 09:36 AM
RandomHero's Avatar
Yes those will come very close to tucking without modification. Usually less than 3" difference between rim width and backspacing is optimal however those will be fine.
Old Aug 19, 2009 | 09:40 AM
what size exactly? i thought that and i have 2 steel stockers but they are 5" or so wide so they need to be widened to work i thought
Old Aug 19, 2009 | 09:42 AM
RandomHero's Avatar
The stock steelies should be a 16x7 if I remember correctly.
Why not just find 2 stock 16x7 aluminum rims? They'll be just as cheap, lighter and easier to find.
Old Aug 19, 2009 | 10:06 AM
will the 7" be wide enough (your right i just went and measured)? if so i will just use what i have in 16s
my plan is a 28x10 slick
Old Aug 19, 2009 | 10:47 AM
Phantom's Avatar
11 Second Club
those wheels you listed ALMOST tuck but not quite
Old Aug 19, 2009 | 10:56 AM
LowBlack99's Avatar
I put em steel wheels because I had them, they are to narrow for the tire I run which is a 315/35/16 it's about 12in wide but due to the narrow wheel only about 9-10 contacts the ground. I plan on getting bigger wheels when money allows.
The wheels you were looking at will work with a 10in slick just fine. I looked at some 16x10's awhile back and they werent much more than those.
Old Aug 19, 2009 | 11:24 AM
they give too damn many options!!! if they come close to tucking i should be fine with it. but damn all these options lol
Old Aug 19, 2009 | 11:27 AM
RandomHero's Avatar
I had some 16x10s for sale for $70 plus shipping for both(2). No one wanted them though. They're back at my parent's house.
