Idle oil PSI is only 34psi, even with thicker oil????
Old Apr 1, 2007 | 09:15 PM
Default Idle oil PSI is only 34psi, even with thicker oil????
I have run M1 5-30 since I had 1,000 miles on this motor and when warm it idles at just 34psi. ALL my other GM's have idled at 40psi but this one. I recently switched over to RP 10-40 and still no change in pressure. I have logged it with HPT, so the gauge is not wrong. I have 38K on the motor now and will be putting a Radix on it when I get a chance to get home and want this motor to last.
Is this OK, or should I be worried?
Old Apr 2, 2007 | 01:05 AM
allenmehrer's Avatar
can't give you a good answer on if its good or not but mine runes the same
Old Apr 2, 2007 | 09:18 AM
Tootall's Avatar
I'm a little over 44 psi with my new motor, running 10-30
Old Apr 2, 2007 | 09:25 AM
zippy's Avatar
I think that is just fine. That's more than enough pressure for idle. What is more of a concern is how much pressure you have at higher rpm's. You want at least 10psi per 1000rpm.
Old Apr 2, 2007 | 05:32 PM
MonteCarlo31's Avatar
thats where I'm at w/ 5w30 thats been in the engine for 10,000 miles
Old Apr 2, 2007 | 05:45 PM
CHEVRACER83's Avatar
Im Running Synthetic 5-30 And Im Getting The Same.... The Reason The Oil Weight Change Didnt Change The Pressure Is Because I Believe The Relief Spring May Be Limiting It To That Pressure
Old Apr 3, 2007 | 03:49 PM
TURBHOE's Avatar
which filter are you running? i know you found a bunch of them on sale that time.
B.love18
Sep 21, 2015 08:31 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
