Idle oil PSI is only 34psi, even with thicker oil????
I have run M1 5-30 since I had 1,000 miles on this motor and when warm it idles at just 34psi. ALL my other GM's have idled at 40psi but this one. I recently switched over to RP 10-40 and still no change in pressure. I have logged it with HPT, so the gauge is not wrong. I have 38K on the motor now and will be putting a Radix on it when I get a chance to get home and want this motor to last.
Is this OK, or should I be worried?
Im Running Synthetic 5-30 And Im Getting The Same.... The Reason The Oil Weight Change Didnt Change The Pressure Is Because I Believe The Relief Spring May Be Limiting It To That Pressure
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
