I just scored big time :)
Old Oct 26, 2006 | 02:28 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default I just scored big time :)
I just got my hands on a LS1 bottom end complete with block, rotating assy, Lifters, covers, oil pan, cam, and EVERYTHING for $150 from a guy I know off LS1 Tech... The only damage is a scratch in one of the cylinders that can be honed easily...
How big can you bore a stock LS1 without re-sleeving? I was thinking about taking it .030 out and putting pistons in it and calling it good. I plan on running my whole top end. intake, heads, acessories... everything... just the aluminum block and LS1 bottom end.
What all will have to be done to make the swap??? I needed to pull it apart to get at the converter and change the flexplate anyway... why not put a new motor in it while I'm at it
LS1 Swap guys, help me out here...
Old Oct 26, 2006 | 03:12 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
.01 I believe all you can get overbore on them the sleeves are THIN!
Old Oct 26, 2006 | 03:29 PM
bluecajun5.3's Avatar
11 Second Truck Club
3.905 i believe is a magic bore they go with.
Old Oct 26, 2006 | 03:31 PM
BLACK04VHO's Avatar
yeah .010 is it. I know it sucks but sleeves cost some $$ that's why alot of them are going to the ls2 block.
Old Oct 26, 2006 | 08:55 PM
quicksilverado's Avatar
Most go 3.905 because the pistons are readily available. You could stroke it to 382 ci I believe.
Old Oct 26, 2006 | 11:18 PM
TwoFast4Lv's Avatar
10 Second Club
Get a 6.0L block and bigger pistons then go to town
Old Oct 27, 2006 | 08:44 AM
Hunt&Fisherator
well my parade got rained on as fast as it started.... they guy found a crack in the side of the block and its no good... oh well, still looking...
Old Oct 27, 2006 | 10:01 AM
Zick's Avatar
Yup, move on.
Btw, '98-'99 you can only do a light hone whereas '00+ you can bore I believe .01". Appearently the earlier blocks had thinner sleeves than the later ones.
blownss27
Oct 27, 2015 11:42 AM
stock48
11
Aug 18, 2015 05:55 AM
sprayedenali
17
Aug 7, 2015 08:15 AM
low2001gmc
Jul 23, 2015 05:10 PM
jmarkway
Jul 18, 2015 09:23 PM
