hydro boost or vacuum canister
Old Feb 13, 2011 | 11:08 PM
iamkeniff's Avatar
Default hydro boost or vacuum canister
well...i got the 6.2/6L80e working perfectly. i love the way the truck drives, and the way it pulls to 6500 the thing i hate is when its time to stop with this big cam, stock converter.
im kicking around the idea of swapping to Hydro boost. 400-600 depending what i can grab cheap.
the vacuum canister is on JEGS/Summit for about 100ish. black, chrome, polished.
who runs a vacuum canister on their big cam, stock converter trucks?
228/236 112+2 comp lobes i think, dont know the exact lobe design.
Old Feb 13, 2011 | 11:27 PM
Stoichiometric's Avatar
Pu the hydraulic booster on. You will have more braking power than if your stock vacuum booster was working properly.
Old Feb 13, 2011 | 11:41 PM
iamkeniff's Avatar
it worked well with the converter, but now that i plan on staying with a stock converter. i love the way this thing runs as it is!
i guess imma look into the hydro boost set up. i dont have the cash to waste right now on a large swap like this thanks to a house note coming up.
Old Feb 15, 2011 | 04:59 PM
brent5631's Avatar
+1 on hydroboost. Stops way better now. And I only have a little less than 300 in my setup.
Old Feb 15, 2011 | 05:56 PM
Bumpers's Avatar
from what i here hydroboost is the way to go... i plan to do it one of these days
Old Feb 15, 2011 | 06:05 PM
Atomic's Avatar
I have a gauge for that
I did a writeup on it and put it on a couple forums. Total cost for mine was around $200.
Old Feb 16, 2011 | 04:14 PM
iamkeniff's Avatar
i know....i seen it on GMfullsize.com and it got me thinking
i dont feel like searching for the thread again, but did you reuse your stock PS pump and just T into the return line? i think i seen only 2 fittings on the PS pump, i could be wrong.
no one has done a Hydro set up on the 07+ have they? its kinda cool being the 1st to do it
Old Feb 16, 2011 | 04:19 PM
Atomic's Avatar
Yep, just T'd it.
Old Feb 16, 2011 | 04:25 PM
iamkeniff's Avatar
hmmmm so all i need is the lines, the brake pedal, the booster i may just have to do it!
Old Feb 16, 2011 | 04:27 PM
Atomic's Avatar
Yep, I got all the parts I needed for under $200
