HVAC Mode actuator
It started with no a/c, so I tracked down the bad blend door actuator and it happen to be the mode actuator. Right under the driver side. Probably the worst one to get to in my opinion. On top of that you have 2 gears to position in order for proper operation(obviously not). After all said and done it all works with the exception that it blows through the vents while on defrost and defrost while on the vents. I'm sure it's a simple fix, but before I go waste more time making sure it's all positioned correctly I would like some feedback. Anyone have this problem. I heard tech II scan tool will re-calibrate but I'm not gonna attack that till I'm sure. Thanks in advance!!
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
MA$TER_E
Sep 9, 2015 03:14 PM
