How many of are running high mileage trucks?
#122
My 2000 RCSB just rolled over 215K this last weekend. The old 4.8 runs fantastically and will be pulled this winter to be replaced by a bottle fed 5.3 (It will be going into a street/strip 02 mustang with a carb and nitrous) The old 5 speed whines like a bitch, and the stock open carrier blew up on me during a failed attempt at a burnout, but gave me a reason to replace it with 4.10's and a posi! Everything else works great! I also plan on swapping to a t-56 this winter.
#124
06 gmc sierra 2500, 288,519 miles,
replaced water pump at 196,218
front wheel bearings at 206,980
first trans rebuild at 279,678
original alternator died at 288,491
other then that nothing but oil changes every 3500 miles with AcDelco filters and a trans flush. have all records for truck since 14 miles because i maintained truck in a fleet then purchased when company retired truck and drive it 63 miles round trip to work daily.
#125
2002 ECSB Z71
211k miles
original motor, trans, front end, rear end and tcase
normal scheduled maint (trans flushed every 50k)
Has had waterpump, rear main seal, oil pan gasket and both front hubs replaced.
I just purchased the truck from original owner about 2 months ago for $800! Was told the motor was done for (had a knocking noise). Drove it home as it still had oil pressure. Turns out whoever did the rear main seal didnt replace the converter bolts or bother to loctite them for that matter and they came loose. Sheered two completely of and the 3rd wasnt far behind. $202 later (New flexplate and some bolts along with misc gaskets) and I was rolling down the road!
Have since installed the RC full leveling kit w/ 285's on NNBS yukon wheels, window tint, new plugs and a set of speed engineering long tubes with a magnaflow. Next up is airaid jr and a 220 cam with tune.
211k miles
#128
2002 has 245k miles...only replaced alternator, fuel pump, trans at 217k, abs module, and brakes.
2007 has 169k miles...replaced all brakes twice, vent valve solenoid twice, and both front hubs.
1999 has 195k miles...unknown (just bought)
#129
2002 ECSB Z71
211k miles
211k miles
Wow, that's one hell of a score! She's a beauty
