How do you remove the door handles. (exterior)
Old Mar 15, 2005 | 01:11 PM
Sunshine's Avatar
Default How do you remove the door handles. (exterior)
Like the title reads, im going to send em off to paint and wanted to know how you remove them, dont want to break something off. TIA.
*edit* Also how do you remove the tailgate handle?
Old Mar 15, 2005 | 01:14 PM
JSmith's Avatar
Click on my sig pic. I have a write-up on how to remove your handles on my webpage.
Old Mar 15, 2005 | 01:16 PM
HI85WH1's Avatar
dont quote me.. but the plastic plug on the door inner comes out , and I believe there is a bolt behind that... but dont forget to disconnect the linkages...
It may be best to remove the door panel to see what you are doing.
JSmith's Avatar
You're correct. It's all documented on my page.
Old Mar 15, 2005 | 04:23 PM
smooth sierra's Avatar
there are 3 nuts total. One is removed by the rubber plug mentioned the other 2 have to come off by removing the door panel on the inside and pulling back the plastic. make sure the window is rolled up all the way and reach your hand up behind the window track and you will find the other 2. you can see them both with a flashlight with the door panel off. It is really not a big deal. I had a 10mm ratcheting wrench that helped out alot. be careful not to drop the nuts in the bottom of the door. Total time approx. 10 min per side. Good luck you can handle it.
Texas5.3_1251
Mar 5, 2016 08:10 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
FlyingLow
Nov 24, 2015 10:05 AM
69z-28
Sep 21, 2015 07:31 AM
