how do I remove the door panel???!!!
Old Nov 24, 2005 | 12:41 AM
Luda 420's Avatar
Default how do I remove the door panel???!!!
How do I remove the door panel on a 2005 sierra? My dad has tried eveything and it wont come off. He does not want to pull it hard because he is afraid of breaking it. Anybody have the instructions?
Old Nov 24, 2005 | 12:48 AM
ridnlow's Avatar
Should be 4 10mm screws, one on verry bottom, one on the arm rest, 2 behind the piece that goes around the door handle if i remember correctly and then you just pull up on it..
Old Nov 24, 2005 | 12:51 AM
you dont' need to take the one on ther very bottom out, it just holds the plastic pocket in. You have to pull up the swtich panels, remove the trim around the handle and remove the sail panel
Old Nov 24, 2005 | 04:48 AM
Jethro_3's Avatar
On the '05 you pull the caps on both sides and the screws behind them. Pull the cover around the handle and the lock. Pull those screws. Lift the panel up and unsnap the 3 wire harnesses. Done. DO NOT PULL UP ON THE LOCK/WINDOW CONTROL PANEL, IT STAYS WIT THE PANEL ON THE '05.... if you do you will mess up the door panel permanently, ask me I almost made that mistake.
Old Nov 24, 2005 | 09:15 AM
CHAGO's Avatar
there's a little bolt under the armrest = 10mm that you unscrew and take out
then you take a flathead and take off the little cover around the door handle
use the same flathead to remove the door lock indicator
then just pull up on the panel to unsnap it from the holders
what are you trying to do?
Old Nov 24, 2005 | 10:29 AM
Luda 420's Avatar
Im trying to install speakers on it, its a crew cab so would you guys happen to know how take door panels in the back?
Old Nov 24, 2005 | 01:06 PM
CHAGO's Avatar
same way as the fronts
FlyingLow
Nov 24, 2015 10:05 AM
cheyenne383
Nov 13, 2015 09:24 AM
rumblebox
Oct 29, 2015 10:35 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
