Higher Octane??
Octane booster....**** works?? Will it raise 93 to at least 100 octane?? And is that hard on a pretty much stock motor? Just curious before I try it to get rid of some knock and pinging...?? Thanks
i used some octane booster a few times, i couldnt really tell what it did, seemed better but im sure it was one of those mind things, if you get one be sure its rated for off-road use only or it wont be as strong as the others out there... its a waste of money unless you are planning to run some nitrous on a certain tank of gas or you have pinging and such for octane is needed for somethings to work properly but will not benfit other things not tuned accordingly. for example, if you have an 87 octane tune, you will not get any more power out of it with 93
Torco racing fuel concentrate works pretty good,it will make up to 104 octane if you mix in enough concentrate.It's expensive about $18 a can,which mixed with 20 gal of 93 octane will yeild 97 octane unleaded racing fuel.Or you can go to the local paint store and buy a 5 gal container of toulene for about $25 and mix the 5gals with about 25gals of 93 octane for the same 97 octane.With the toulene,it's probably a good idea to add a small amount of lubricant.
