High oil pressure?? hmmm
Old Feb 6, 2009 | 12:59 PM
XLR8NSS's Avatar
Adkoonerstrator
The intake manifold is not tough to remove either, it looks crazy with the wires and stuff all over but, it's like a 15 minute job at most probably.
Old Feb 6, 2009 | 01:16 PM
blkonblk's Avatar
how much $$ is the sender unit going to run me?
Old Feb 8, 2009 | 09:12 AM
Truckshop's Avatar
you don't have to remove the intake. it is pretty easy to change and is less than 20 bucks. but it sounds like it is the cluster. pretty common.
Old Feb 8, 2009 | 04:25 PM
sixltrbtr's Avatar
Changed a sending unit just the other day for the very same reason. Fixed the problem. Don't have to remove the intake unless you just want to. Try the sending unit first it's cheap. There are a lot of problems with the clusters on our trucks though.
Old Feb 10, 2009 | 09:45 PM
blkonblk's Avatar
I guess i have something to do for the weekend.
Old Feb 11, 2009 | 07:55 AM
krambo's Avatar
Originally Posted by blkonblk
true. Where is it located at? and are those easy to replace? can they be replaced or should i just find another way to monitor the oil press.
The socket is over the Oil Pressure "Sender" in the below picture. As mentioned, taking the intake off isn't a bad job. While you are under there, you can clean the intake ports on your heads (most likely gummed up) and check for water intrusion in the knock sensor provisions of the valley cover. May actually wish to put some silicone around the boots.
My knock sensor boots sealed:
Old May 14, 2009 | 07:22 PM
blkonblk's Avatar
thanks for the pics that really helped out. i changed the unit and the psi is back to normal. thanks again for the help
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
