High Oil Pressure
Old Oct 14, 2006 | 10:49 PM
knyznyk's Avatar
Default High Oil Pressure
Hi, I have 05 5.3L RCSB under full throttle the oil pressure goes right to the max...My dads Dodge Ram Hemi under full throttle moves little. Is there a problem with my Silverado or is this a chevy thing? Thanks.
Old Oct 15, 2006 | 12:29 AM
xchevyx24's Avatar
mine dont do that
Old Oct 15, 2006 | 02:30 AM
checked the oil level?
Old Oct 15, 2006 | 07:58 AM
knyznyk's Avatar
Oil level is up, but it does need changing.
Old Oct 15, 2006 | 09:32 AM
Bowtie70SS's Avatar
On my SS the oil pressure sending unit went bad. On the interceptor gauge it read 121psi and on the dash the needle was pegged, even with the engine off. Your sending unit could be bad. Are you running 5W30? If not thicker oil will normally raise your oil pressure, plus the numbers on the factory gauge are a little high...to make you feel good. If you're hitting 60-80psi @WOT then that's fine. Dodge's aren't any good anyway...they don't make enough power to need all that oil pressure
Dave
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
