Help Please!
Old Aug 28, 2011 | 02:43 PM
devink's Avatar
Default Help Please!
to make a long story short, I released my truck from the jack and the oil pan hit a wooden block which I forgot to remove. The oil pan cracked. I feel like a total dip-**** now. I bought a replacement pan, removed the K-member and all oil pan bolts, but can not get the pan off due to the pickup tube not allowing enough clearance between the engine and the cross-member. The pickup tube bolts seem almost impossible to get a wrench on. I'm sure there's a simple solution, but before I lose all my patience and make things worse I figured I'd ask you guys how to fix this. Advice on getting the tube and pan back on would also be greatly appreciated.
Thanks in advance!
Old Aug 28, 2011 | 09:07 PM
devink's Avatar
Bump for the pm crew
Old Aug 28, 2011 | 09:15 PM
06murder's Avatar
you have an engine lift? if so undo the motor mounds n lift it up bout 4 inchs....dipstick tube shouldnt be that hard to get off,well mine isnt.....
Old Aug 28, 2011 | 09:17 PM
chopshop's Avatar
^^^^what he said.
Old Aug 28, 2011 | 09:56 PM
devink's Avatar
Thanks guys
Old Aug 28, 2011 | 10:11 PM
06murder's Avatar
yup no problem..its better then taken it out just unbolt the motor mounds and lift the motor and you should beable to get to it with n/ps
