headlights not working
Old Dec 25, 2010 | 05:38 PM
02gmcbandit's Avatar
Default headlights not working
well i went to crank my truck a hour ago and noticed the lo beam wasnt working on my driver side, and the hi beam bulbs was slightly lit. i thought it may be my HID's so i unhooked it from the driver side but no change, so then i flicked the hi beams on, pass side came on , driver side didnt, flicked them back off and same result, pass lo beam on like norm and hi slightly lit, driver side lo beam not on and hi beam slightly lit. i searched for a fuse or relay but couldnt find any fuses blow and i dont see any relay labled for headlights/headlamps. any help would be greatly appreciated
Old Dec 25, 2010 | 08:23 PM
Mrgoodwrench3's Avatar
You have aftermarket HID's ? Try switching left to right low beams and see if it works. I see a lot of bulb and balast failures on the aftermarket kits.
Old Dec 26, 2010 | 02:31 PM
problem fixed, bad ballast and blowed fuse. back to stock lights for now thanks.
Old Dec 26, 2010 | 03:42 PM
lady3bglover's Avatar
No ****.. I have the same issue but the hi's come fine. My set up is 2 low and 4 hi, maybe it's the low beam ballast. I've checked every fuse and relay, that maybe it.
Old Dec 26, 2010 | 03:50 PM
gcsd3742's Avatar
AH ha. this is why your asking me ?'s I knew that ? was going somewhere...
Bluchevypick
Aug 18, 2015 09:11 AM
HIDEXTRA
Jul 21, 2015 05:43 PM
atxlt
Jul 20, 2015 11:06 PM
Blackrat48
Jul 11, 2015 12:36 PM
banker099
Jul 4, 2015 05:50 PM
