have a question for those of u who have cut the front springs.
Old Nov 29, 2009 | 07:03 PM
  #21
bluecajun5.3's Avatar
11 Second Truck Club
cool deal.
i don't use a compressor but use a ball joint separator.
i will try it by unbolting the lca next time, sounds much easier.
Old Nov 29, 2009 | 07:06 PM
  #22
JoeGibbSilverado's Avatar
damn ball joint boots tear easy, so be careful....lol
Old Nov 29, 2009 | 10:48 PM
  #23
bolikes2skate's Avatar
theres actually 3 auto zones within a 10 mile radius from me also 2 orielys and 2 advanced auto parts lol oh and a car quest.
but the compressor sound like a pain if its not necessary ill probably try with out it
Old Nov 30, 2009 | 09:47 AM
  #24
TXsilverado's Avatar
its really not bad at all. slip on spring compressor in through the shock hole in the bottom of the lower control arm and hit it with a impact. put the other on the outside of the spring and impact it too. i did the whole process yesterday no problem.
Old Nov 30, 2009 | 10:35 AM
  #25
dlt76028's Avatar
your not suppose to use an impact on compressors, they slip from the shaking and literally can blow up in your face. the ones i have rented are never big enough for the spring either. the cup on the end of the arm doesn't fit over the spring.
Old Nov 30, 2009 | 10:38 AM
  #26
ive never had a problem using an impact. they hold every time. theres no way in hell to do it by hand on a spring thats alreay removed.
i do think ill dry dropping the lower control arm next time though and see how that goes.
  #27
Old Nov 30, 2009 | 10:53 AM
  #28
dlt76028's Avatar
one piece of advice when dropping the LCA, put a 2x4 under it on both arms. it helps keep it even when jacking it back up, and getting the bolts it.
Old Nov 30, 2009 | 11:04 AM
  #29
ive never had problems with the compressors slipping or the impact moving anything. good luck cranking those things down by hand with a spring laying on the ground.
i think next time i will try dropping the lower control arm.
Old Dec 1, 2009 | 10:32 AM
  #30
i took one of my wheels off to look at what im gonna be dealing with n no one really said anyting about the shock. i notice two nuts on the bottom of the shock like on the bottum of the coil from under the lca. do i just leave those alone?
