Hard cold start 1x
2007 Sierra Classic.
As it has gotten cooler out, the first time I turn the key, the truck will start, run rough and then die. If I try to start it again, whether I wait or do it immediately, it fires up fine and doesn't act like anything is wrong. It's worse the colder it is, better when it is hotter out.
I have tried diagnosing the fuel pump/FPR by leaving it on for 3 to 10 seconds before attempting to start and it does not make a difference. Once it is started and running I have no issues starting it the rest of the day.
Fuel pressure was good while running, which leads me to believe it might be injectors leaking overnight..? I did run some BG 44k through it made not much of a difference either way.
Video below of the other day.
https://photos.app.goo.gl/WzVZCHyp8gRGyLfN8
Truck runs fine otherwise. It gets used daily pulling a trailer with lawn equipment and does not idle funny, stumble, or feel down on power. It's basically starting and stopping every 15-60 minutes before being parked for the night.
Hook up a fuel pressure guage when you park it overnight, and check on it the following morning before priming it. Bleed-down I believe is normal, or some bleed-down overnight. You may have an injector that leaks after cooling down, and the trucks stalls in the morning because it's flooded. You can also monitor fuel trims when this happens, if you have a scanner with live data.
If it's running really rich, you can try inducing a vacuum leak temporarily, by simply unplugging an intake hose and see what happens...
Originally Posted by HawkZ28
...I have tried diagnosing the fuel pump/FPR by leaving it on for 3 to 10 seconds before attempting to start and it does not make a difference...
It won't make a difference if you do it that way. The fuel pump prime is timed, it only lasts like 2 seconds, I'm not sure exactly. To test it by trying to prime it before you start it cold, you have to turn the key on for a few seconds, like 3 seconds, turn it off, and repeat a few, maybe 3, times. Besides a leaking injector, a leaking regulator is also a possibility.
Interesting development.
When I was having the issues, I had started running 91 clear fuel and added BG 44k to the first tank. I believe I had at least two, maybe three tanks in a row of 91 clear where I experience the issue.
The other day I filled up with E10 87, and now the problem has gone away. It has fired up immediately without allowing the pump to even prime. 65* one day, 45* the next.
RONIN LSX
Mar 25, 2016 08:36 AM
91_bowtie
Dec 1, 2006 01:40 PM
Slammedchevy01
17
May 4, 2005 03:02 AM
